kmh7189
Mar 20, 2020Aspirant
Orbi satellite pulses white
Rbs50 satellite just arrived. Adding it to existing rbr50 and rbs50 satellite. plug it in, will not stop pulsing white. Tried reset and nothing changes. Can't sync until that pulsing white goes a...
CrimpOn
Mar 20, 2020Guru - Experienced User
kmh7189 wrote:Rbs50 satellite just arrived. Adding it to existing rbr50 and rbs50 satellite.
Plug it in, will not stop pulsing white. Tried reset and nothing changes. Can't sync until that pulsing white goes away.
According to Netgear's web site, "Pulsing White" means "applying a configuration or updating firmware."
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
Is this a "brand new RBS50 or purchased used"? If it is brand new, you can call Netgear within 90 days of purchase for "complimentary support."
When you did the "Factory Reset" did the power LED do as it does in the video?"
kmh7189
https://www.youtube.com/watch?v=cMw4ePACgc4
it was purchased used . so as soon as you plug it in, it flashed white on and off and doesnt stop. when i push factory reset, the power led does not turn amber and flash like video, and the led ring just keeps on flashine white.
- CrimpOnMar 20, 2020Guru - Experienced User
One user reported an undocumented method for resetting an Orbi:
Press paperclip in reset hole for 30 seconds
Keep pressing paperclip while removing power
Keep pressing paperclip for another 30 seconds while apply powerIf that doesn't work, you can try the "Trivial File Transfer Protocol" (TFTP) method:https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client This is not for the faint of heart. After downloading and unpacking the satellite firmware from Netgear's support web site, these directions will "push" firmware directly onto the Orbi and then restart it.
- kmh7189Mar 20, 2020Aspirant
CrimpOn wrote:One user reported an undocumented method for resetting an Orbi:
Gave the reset method a try and no change. Luckily I bought it with 100% free return and shipping....so back it goes! Thanks for the ideas.
