Jerydown
Feb 23, 2019Aspirant
Orbi Satellite RB550 will not reset or sync
I have tried to sync. I have tried to reset. Satellite just stays white. Will not go into sync mode. Any thoughts to reboot or get it to sync?
Chuck_M
Feb 23, 2019Mentor
Just to be sure:
Factory Default Reset:
https://www.youtube.com/watch?v=cMw4ePACgc4
Wait for the Amber blinking!
And then Synch
Synch instructions:
https://www.youtube.com/watch?v=ePZSc7vnRlQ
Jerydown
Yes I have done this. Is there a hard reboot or a way to send to netgear for a new one. It will not reboot by resetting to factory default.
- Chuck_MFeb 23, 2019Mentor
Based on the limited info you have provided, it sounds to me its time for you to contact NG tech support and ask for a replacement.
Hope it is still under warranty.
