Jerydown
Feb 23, 2019Aspirant
Orbi Satellite RB550 will not reset or sync
I have tried to sync. I have tried to reset. Satellite just stays white. Will not go into sync mode. Any thoughts to reboot or get it to sync?
Jerydown
Yes I have done this. Is there a hard reboot or a way to send to netgear for a new one. It will not reboot by resetting to factory default.
Chuck_M
Feb 23, 2019Mentor
Based on the limited info you have provided, it sounds to me its time for you to contact NG tech support and ask for a replacement.
Hope it is still under warranty.
