Raulillo24
May 02, 2018Aspirant
Orbi Satellite RBK50
Why my Orbi satellite-1 in the Backhaul Status shows POOR?
this satellite is about 30 to 35 feet from the main Orbi base
my home is about 1750' sf
my internet speed is 120 mb
May 02, 2018Guru - Experienced User
What kind of building materials is your home made off? wood or concrete?
Single story or multi?
That size of home, you can use the router alone if placed centraly in the home and should cover have good signal range
- Raulillo24May 03, 2018Aspirant
the house is in concrete, the main unit is in one corner of the house and the sattellite is in one bedroom basically in the midle of the house.
- Dawsson46May 03, 2018Aspirant
What's the signal strength from the router at the satellite location on the upper 5ghz band? Are other Wi-Fi networks using the upper band?
yes 5ghz
no, theres no other network
- FURRYe38May 09, 2018Guru - Experienced User
Ya, concrete will not be good for 5Ghz due to it's high frequency.
