Raulillo24
May 02, 2018Aspirant
Orbi Satellite RBK50
Why my Orbi satellite-1 in the Backhaul Status shows POOR?
this satellite is about 30 to 35 feet from the main Orbi base
my home is about 1750' sf
my internet speed is 120 mb
Raulillo24
May 03, 2018Aspirant
the house is in concrete, the main unit is in one corner of the house and the sattellite is in one bedroom basically in the midle of the house.
Dawsson46
What's the signal strength from the router at the satellite location on the upper 5ghz band? Are other Wi-Fi networks using the upper band?
- Raulillo24May 03, 2018Aspirant
yes 5ghz
no, theres no other network
- Dawsson46May 03, 2018Aspirant
That isn't signal strength its measured in db. If you have an android there are tons of wifi analyzer or a laptop with InSSIDer
- Arcana13May 03, 2018Aspirant
My satelite is also shown backhaul signal poor.
Mine is not even on 5G band for the backhaul
Does anyone know how to set the backhaul band?
I am on firmware 2.1.4.10
satelite is 30feet apart from the router, building material is wood stub and sheetrock
