Brad_Matthews
Jul 06, 2019Follower
Orbi Satellite RBR50 Not Connecting via Ethernet
New Orbi user. After having poor Etherner connectivity issues with the RBR50 on my 2015 McBook Pro running Mojave, I contacted my Gigabyte Internet provider. We confirmed via their modem directly con...
michaelkenward
Jul 07, 2019Guru - Experienced User
What firmware version do you have on the device? A number is more useful than "the latest". (It may not be by the time people read this.)
There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
Brad_Matthews wrote:
We confirmed via their modem directly connected to my MacBook that the fiber line coming into the house was performing as expected. We were able to hit 949MBps (down) and 790MBps (up), so he wiped the devices and he could see the Orbi on his end once reconnected.
It might also help if you told people what "their modem" is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
