Brad_Matthews
Jul 06, 2019Follower
Orbi Satellite RBR50 Not Connecting via Ethernet
New Orbi user. After having poor Etherner connectivity issues with the RBR50 on my 2015 McBook Pro running Mojave, I contacted my Gigabyte Internet provider. We confirmed via their modem directly con...
Jul 07, 2019Guru - Experienced User
Yes would like to know what ISP Modem or ONT is in front of your Orbi router.
What mode is your Orbi running in? Router or AP mode?
Brad_Matthews wrote:New Orbi user. After having poor Etherner connectivity issues with the RBR50 on my 2015 McBook Pro running Mojave, I contacted my Gigabyte Internet provider. We confirmed via their modem directly connected to my MacBook that the fiber line coming into the house was performing as expected. We were able to hit 949MBps (down) and 790MBps (up), so he wiped the devices and he could see the Orbi on his end once reconnected.
We tested the connection on the Orbi again and were unable to get over ~250MBps (down) and ~80MBps (up), so he suggested a few small changes to the Orbi settings but nothing worked.
Before I return the Orbi, what other settings should I be adjusting to achieve better results with the Orbi system.
Thanks,
Brad
