corMimi
Jan 29, 2024Follower
Orbi Satellite RBS10 no power
I have a Orbi router and 2 satellites RBS10. The router and one satellite are working fine but the 3rd satellight started making a very faint beeping sound which it took me a while to find out where the beeping was coming from. I unplugged it and later the next day I plugged it in and the satellight will not power on. At first I thought it was the plug, but I tried using the plug from the one that was working fine and it still is dead. Any ideas or is it unfixable?
thanks in advance
1 Reply
Assuming that the electrical outlet is OK, it appears that the satellite has failed.
Just to be 100% certain, there would be no harm in doing a Factory Reset on the satellite. (not the whole system)
Unlike most Orbi models, the RBS10 does not appear to have a Power LED next to the power plug.
When plugged in, does the LED on the front show anything?
