Cornelia1204
Jun 24, 2020Aspirant
Orbi Satellite (RBS20) can't stay connected to Router (RBR50)
I have been trying to connect an Orbi RBS20 to my RBR50 router, but it won't stay connected for long. Here's the steps I did: -Rest the satellite (pressed on the pin for as long as 30 seconds) -...
Jun 24, 2020Guru - Experienced User
What Firmware version is currently loaded on the RBS and RBR?
Did you press the sync button on the RBS first then the sync button on the RBR by chance as well while in the same room?
I noticed that my RBS20 also turned BLUE, then Magenta, then back to BLUE then finally OFF. It took several minutes to completely connect.
What is the distance between the router and satellite(s)?
Cornelia1204
Currently, both my RBS and RBR's firmware version is V2.5.1.16.
I tried:
-Press sync on RBS first then on Orbilogin
-Click Sync on Orbilogin first then press sync on RBS
-Press on RBR and RBS at the same time (both just one time and held down while pressing the sync)
-Connected the RBS directly to RBR, that's when the sync will stay for the longest time (about 2 mins), but then turn to magenta and stays in magenta
Currently the RBR and RBS are in the same room, about 8 ft apart. When I directly connected the RBS to the RBR, the 2 units are next to each other.
Since the last time I tried to sync (which was synced successfully initially), the magenta light is on for the past 20 mins+, I doubt it will turn back to blue :(
- FURRYe38Jun 24, 2020Guru - Experienced User
Has a factory reset on the RBR and the RBS been performed then walk thru the setup wizard?
- Cornelia1204Jun 24, 2020Aspirant
I'm pretty sure I have tried factory reset both. I know for a fact I factory reset the RBS in question many times.
I will try to reset RBR, turnoff and remove the other 2 RBS after work today, and see if that fixs it. Thanks!
Ok, keep us posted. It should connect then.
