Cornelia1204
Jun 24, 2020Aspirant
Orbi Satellite (RBS20) can't stay connected to Router (RBR50)
I have been trying to connect an Orbi RBS20 to my RBR50 router, but it won't stay connected for long. Here's the steps I did: -Rest the satellite (pressed on the pin for as long as 30 seconds) -...
Cornelia1204
I'm pretty sure I have tried factory reset both. I know for a fact I factory reset the RBS in question many times.
I will try to reset RBR, turnoff and remove the other 2 RBS after work today, and see if that fixs it. Thanks!
Jun 24, 2020Guru - Experienced User
Ok, keep us posted. It should connect then.
- Cornelia1204Jun 24, 2020Aspirant
Unfortunately that didn't work either :(
Here's what I did:
-Unplugged other RBS
-Removed them from the "Attached Devices" (although this doesn't really matter since I'll factory reset RBR next)
-Factory Reset RBR and RBS, waited until the orange light blinking
-Followed the Orbi App to "Set up a new system"
-Unplugged and replugged the modem, connected the lan cable between modem and RBR
-After everything booted, pressed the sync botton trying to sync the satellite to the RBR
-Both the App and Orbilogin page showed no satellite detected
- FURRYe38Jun 24, 2020Guru - Experienced User
Sounds like mayby the one RBS is not working right and is faulty. I recommend getting it replaced.
- Cornelia1204Jun 24, 2020AspirantThat's what I thought, too. Just wanted to make sure I tried everything before getting rid of it. Thanks for the help!
