pugwonk
Sep 04, 2019Tutor
Orbi satellite RBS50 dropping ethernet for a few seconds
I have a network set up with an RBR50, RBW30 and RBS50. It works great most of the time. However.... I have two computers plugged into the RBS50 via ethernet and every so often (twice a day or therab...
- Oct 31, 2019
About a week in now and, for me at least, I can confirm that the V2.5.0.38 firmware fixed this issue. Amusingly this firmware update arrived the same day as the 100ft ethernet cable I was about to run up the main stairs in the house, much to the annoyance of my wife...
Oct 23, 2019Guru - Experienced User
Good to hear. Glad the new FW update fixed this for you.
Be sure to do a backup configuration to file for safe keeping.
Please mark your post thread as solved so others will know.
Enjoy.
Retired_Member
Oct 23, 2019
FURRYe38 wrote:Good to hear. Glad the new FW update fixed this for you.
Enjoy.
What's to know? If you're insinuating that V2.5.0.38 fixed the problems created in 2.3.5.30, it's more than likely a isolated situation.
