pugwonk
Sep 04, 2019Tutor
Orbi satellite RBS50 dropping ethernet for a few seconds
I have a network set up with an RBR50, RBW30 and RBS50. It works great most of the time. However.... I have two computers plugged into the RBS50 via ethernet and every so often (twice a day or therab...
- Oct 31, 2019
About a week in now and, for me at least, I can confirm that the V2.5.0.38 firmware fixed this issue. Amusingly this firmware update arrived the same day as the 100ft ethernet cable I was about to run up the main stairs in the house, much to the annoyance of my wife...
pugwonk
Oct 31, 2019Tutor
Oct 31, 2019Guru - Experienced User
Glad the new FW fixed your problems.
Was curious if you updated FW and continued to use the system or did you factory reset and setup from scratch? Just curious.
Enjoy the system.
pugwonk wrote:About a week in now and, for me at least, I can confirm that the V2.5.0.38 firmware fixed this issue. Amusingly this firmware update arrived the same day as the 100ft ethernet cable I was about to run up the main stairs in the house, much to the annoyance of my wife...
- pugwonkOct 31, 2019Tutor
FURRYe38 wrote:Glad the new FW fixed your problems.
I just updated FW; no factory reset.
- FURRYe38Oct 31, 2019Guru - Experienced User
Kewl, glad it's working, with out a reset.
Enjoy. :smileywink:
