ttrappe
Jul 22, 2020Initiate
Orbi Satellite (RBS50) Ethernet/LAN Port Speed on Gigabit Internet
I recently installed a RBK50 Router (RBR50) and Satellite (RBS50). Both are working fine. I have Gigabit internet running through a SB8200 Gigabit modem. Through some controlled speed testing, I get 9...
Jul 22, 2020Guru - Experienced User
Faster than wired? No.
It has a 1733mbps backhaul. And that's link speed. Link speed isn't throughput speed. throughput is roughly 55-65% of what the link speed is. And if they were right next to each other, they might get the full 1733mbps link speed. but they need to be at least 30ft apart. And they're 5ghz so you see speeds drop off faster because it doesn't broadcast as far or through as much materials.
So its a great feature as the wireless backhaul lets you spread them out but it isn't going to be as fast as a wired backhaul with the AC versions.
btv_94
Aug 17, 2020Guide
Will it be a problem for ethernet backhaul if RBS50 is about 17ft-20ft and 6 walls apart from RBR50 (2 bathrooms and 1 furnace closet).
Currently my download speed on iPhone is only 2-3Mbps and yet if I'm in the living room where my router is located my download is about 220Mbps.
I'm planning to get RBK50 is it's going work.
Thanks,
Set up: Ethernet backhaul.
Modem to RBR
Ethernet cable from RBR to 1G switch
Ethernet cable from 1G switch to RBS.
17ft-20ft apart with 6 walls.
- MstrbigAug 17, 2020Master
btv_94 wrote:but they need to be at least 30ft apart.
Thanks,
Modem to RBR
RBK50 is a nice system. No you won't have a problem. Walls add to the equation. If you run into issues you can always adjust the power.
- FURRYe38Aug 18, 2020Guru - Experienced User
Should be 30 feet or more in between the RBR or RBS, regardless if wireless or wire connected. If the RBS can't be moved farther, reduce the power output of the RBR from 100% to 50%.
Under Advanced Tab/Advanced Settings/Wireless Settings
Thanks,
Modem to RBR
