vinlaunch
Feb 21, 2019Tutor
ORBI Satellite RBS50 not connecting (and top LED not lighting)
Hello all,
I have an ORBI router (RBR50) and satellite (RBS50) and have realized that the satellite is not connected or functioning. I have attempted to resync but it is not working. The satellit...
rapidsft
Jun 08, 2021Aspirant
I have the exact same issue you have. The unit appears to be dead. The other Satallite works but the other one does exactly what yours does. Did you get Netgear to actually do an R.M.A for you. I need to do the same.
Jun 08, 2021Guru - Experienced User
You can try opening a support ticket here:
https://www.netgear.com/mynetgear/registration/login.aspx
If you have had the system beyond 90 days, you may need to pay the fee to get in contact with them.
RMA= Return Material Autorization. Where they send you a working unit for a defective unit.
