paulretail
Jul 13, 2022Aspirant
ORBI satellite RBS50 not responding,
My satellite RBS50 has stopped working it is powered up but there is no pulsing lights showing at the top of the satellite . I've tried to do a factory reset and it hasn't made and difference. The f...
- Jul 13, 2022
If you hardwire it into your router and give it 5 minutes. Does it show up in the attached devices page then?
paulretail
I've hardwired the router to the satellite as suggested and is showing as no connected device found. On the network map the dot next to the satellite is magenta and the device has a wifi symbol in red.
ekhalil
Jul 20, 2022Master
In the web GUI, under Attached Devices, you should see the satellite as offline, click on the button that says "disconnect" to forget the satellite and do the pairing again.
