calisleo
Mar 20, 2019Follower
Orbi Satellite RBS50 only
Hello,
Can i buy Orbi Sateelite RBS50 only can connected to my exisitng router to use to extended my WIFI
Thanks
- Unfortunately the answer is no..
You cannot use the Satellite as a stand alone unit. It requires a functioning Orbi Base device such as an RBR50 to function at all..
- ReddkingGuideUnfortunately the answer is no..
You cannot use the Satellite as a stand alone unit. It requires a functioning Orbi Base device such as an RBR50 to function at all.. - FURRYe38Guru - Experienced User
As Redking mentioned you can't use the satellite initially with a different Mfr router.
I have experienced that after a satellite IS connected to a Orbi system via ethernet backhaul first, and you swap out the base router for something else, if you re-connect the LAN cable to the satellite to the new router, my satellite remained working. I presume that at if the satellite was reset to factory, it would not work again untill it was re-synce with the Orbi system.
calisleo wrote:
Hello,
Thanks
