takobass
Nov 26, 2017Guide
Orbi Satellite RBS50 Pulsing White Forever
Hello. Last night I realized that my Orbi satellite was not connected, so I attempted a reset on both the router and satellite mutiple times, and now, the satellite keeps pulsing white, never connect...
- Jan 03, 2018
Just updating to say I've replaced the hardware via the shop I bought it from (JB-HiFi Carindale FTW!) and am now full armed and operational.
I've set up the new router and satellite and updated the firmare in both to V2.0.0.74. I'm not bold enough to update them manually to V2.1.1.16 yet though.
Good luck to everyone stuck in the eternal booting state.
DarrenM
Jan 02, 2018Sr. NETGEAR Moderator
Hello Takobass
You can try and connect a pc to the unit via ethernet and then try to connect to the unit with either 192.168.1.250 or 192.168.1.1 and see if it will let you log in from there you can do a manual update of the firmware after you download it to your pc from the support site.
DarrenM
Andrew_Scott
Jan 03, 2018Guide
I'm in the same situation: satellite flashes white continuously.
I got my Orbi system yesterday and initially everything seemed to be working but after a while I noticed the satellite (RBS50) ring LED was flashing white. The manual says this is booting but if so it never finishes booting. After pressing the power button the Power LED is solid green initially and after about 18 seconds it flashes red for a few seconds and then returns to solid green. The manual says that a flashing red Power LED indicated the firmware is corrupted but it doesn't stay flashing red.
I've tried everything I can think of since then and it remains in the 'booting' state.
- I've tried the factory reset switch on both router and satellite. This works on the router but the satellite just doesn’t seem to respond to the reset switch at all, even holding it for 60 seconds or more.
- I've updated the router firmware to V2.1.1.16, can't access the satellite firmware to update it.
- I've tried connecting the satellite to the router with an Ethernet cable but this makes the satellite Power LED flash red contiuously.
- I've tried connecting the satellite to my computer with an Ethernet cable but can’t establish a connection at 192.168.1.250 or 192.168.1.1 or any of the other random addresses I tried.
My guess is that I have little alternative but to return it to the shop I bought it from unless there is something else I can try.
- Andrew_ScottJan 03, 2018Guide
- takobassJan 05, 2018Guide
I am giving up. I tried manually directly accessing the satellite via ethernet. Nothing works. Initiating RMA process to get a replacement.
Thanks.
- ThedaviddavisJan 07, 2018Initiate
Exact same situation happened to me after 2 days of setup. Satellite starts flashing, never stops. Tried all the suggestions here and am waiting on RMA from Netgear. Incidentally, support didn't even question me on this. It must be a known issue but they do not know how to solve except to replace.
