wifi_en
Apr 21, 2018Star
Orbi Satellite RBS50 Pulsing White Forever
Tried reset multiple times, power LED bllinks red. Bought it from costco will i get it replaced?
Apr 21, 2018Guru - Experienced User
How long did you hold the reset button in? needs 15 seconds before the top LED blinks yellow/orange Then after it start slowly blinking white, hit the sync button on the satellite then select sync on the routers web page under the Add Satellite section.
What version of FW are you using on the router and satellite?
If the above process doesn't work, then contact NG support and ask about an RMA.
