ASGILL
Dec 29, 2021Guide
Orbi Satellite RBS50 Pulsing White
My RBS50 started loosing WiFi connection recently, I power cycled it, after power cycle, RBS50 white light started flashing-days. I have facotry reset whole system, router RBR50 has come back online...
Dec 29, 2021Guru - Experienced User
Try this:
What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite📡. Already have the most current or same FW version as whats loaded on the RBR, files downloaded on to this PC.
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite📡. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites 📡 web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites 📡 to the RBR.
Let us know if this works...
- ASGILLDec 30, 2021GuideHi,Thanks for responding, I tried all that but unable to connect to RBS50, Ipconfig shows ip address to be 192.168.1.4, no luck with that either, you have any other ideas?I tried reset by pressing reset button, waited for over 30 seconds, power led was blinking red, after about 60 sec, i disconnected power from RBS while still pressing reset button, reconnected power, after few seconds led turned different color, red to magenta blinking, thank solid green, removed reset pin, waited over 5 mins, connected RBS with ethernet cable to my Win10 PC, got no response to 192.168.1.250 or other ip address, admin and password as suggested was usedI observed i had internet connection though, not sure if RBS has synced to RBR, no way to check because still having problems with connecting to router with app or desktop
