GB67
Jul 02, 2018Aspirant
Orbi Satellite RBS50 requires new firmware
RBS50 - - My RBK50 system is recently purchased and upon first installation I cannot get the satellite (RBS50) to sync. The base station works, (AP mode) but the satellite continuously flashes white ...
DarrenM
Jul 02, 2018Sr. NETGEAR Moderator
Are you able to connect a ethernet cable to the satellite? if so you will want to go to the Ip address of the unit in the web browser and then login with admin/password and you can manually update the firmware of the satellite unit.
DarrenM
