skylinetrain16
Jul 06, 2020Tutor
Orbi Satellite RBS50 Solid Magenta after Factory Reset
hi all, as the title states my orbi satellite may have just crapped out on me but i'm not sure. its on the latest firmware which i upgraded to a few weeks ago and was working fine. its showing th...
skylinetrain16
Jul 07, 2020Tutor
I have two satellites and both are on the same FW as the RBR but only one is acting up. I've repositioned that one and factory reset it over a dozen times now.
I was hoping to not have to reset the main router and other satellite but looks like I'll have to try that out.
Jul 07, 2020Guru - Experienced User
Also after the reset, swap positions with the working RBS to see if the problem follows. If it still continues, then the one RBS maybe faulty. Something to contact NG about to see if they can help you further.
- skylinetrain16Jul 07, 2020Tutor
Resetting router help get the satellite back but now i've noticed that my playstation is losing connection via lan and wifi.
