oabdali
Sep 30, 2022Aspirant
Orbi Satellite RBS50
I have had RBS50 for sometime now like 2-3 years. I have 3 satellites usually connected wirelessly without a single issue. Now I have created a new underground room and connected it using ethernet to ...
- Sep 30, 2022Connected to RBS and yes Cat6. The satellite has been synced when it was in the other room. It is a bit far to try to connect them wirelessly but i can try…
oabdali
Sep 30, 2022Guru - Experienced User
As a quick test, does the one RBS connect to the RBR and sync ok?
Wondering if wiring to another RBS maybe a problem.
