oabdali
Sep 30, 2022Aspirant
Orbi Satellite RBS50
I have had RBS50 for sometime now like 2-3 years. I have 3 satellites usually connected wirelessly without a single issue. Now I have created a new underground room and connected it using ethernet to ...
- Sep 30, 2022Connected to RBS and yes Cat6. The satellite has been synced when it was in the other room. It is a bit far to try to connect them wirelessly but i can try…
Sep 30, 2022Guru - Experienced User
Is the RBS connected to the back of the RBR or another RBS?
What CAT# lan cable is being used? CAT6 is recommended.
Did you first sync the RBS to the RBR wirelessly, then after thats synced, plug in the RBS via ethernet cable?
