iScream
May 19, 2021Aspirant
Orbi Satellite RBS50v2 - Blinking White Light - Can't Re-Sync or Reset
"Your complimentary technical support expired on 2020-04-15" How fitting, that exactly after one year my Orbi RBS50v2 Satellite just died. Symptoms are: - Continuous blinking white light - Th...
CrimpOn
May 20, 2021Guru - Experienced User
iScream wrote:
Before I throw the satellite away -- Is there any option left?
A last resort is to attempt to flash firmware to the satellite using the Trivial File Transfer Protocol (tftp).
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
This is not for the technically shy. The computer being used to tftp has to be changed to a static IP address for this task and then changed back before reconnecting to the network. Wiindows has a tftp program in the "Widows Features" which can be activated. I used the one recommended in one of those articles.
I have done this successfully a couple of times. Download firmware for the RBS50v2 satellite from the Netgear support site:
https://www.netgear.com/support/product/RBS50v2.aspx#download
Choose the firmware version that matches the router firmware. (The "+" sign displays all versions of firmware that are available.)
Unpack the zip file to extract the *.img file for the satellite.
I have found that tftp is touchy. There is a brief window of time after a unit is powered up when it looks for a tftp connection. After that, it has moved on to regular startup and no longer accepts tftp. It has taken me 6-8 attempts to get the magic "file transferring" notice.
Also, I am not entirely clear which IP address the satellite will be at during this brief time. Cannot remember if it was 192.168.1.1 or 192.168.1.254 or......
May 21, 2021Guru - Experienced User
Need to press the reset button for 30 seconds then release, then use PUT on the TFTP app to upload the FW file.
- DLynchSep 23, 2021AspirantWhat do you change in the TFTP instructions in terms of static IP, subnet mask, etc to use with a satellite vs a router?
