iScream
May 19, 2021Aspirant
Orbi Satellite RBS50v2 - Blinking White Light - Can't Re-Sync or Reset
"Your complimentary technical support expired on 2020-04-15" How fitting, that exactly after one year my Orbi RBS50v2 Satellite just died. Symptoms are: - Continuous blinking white light - Th...
May 21, 2021Guru - Experienced User
Need to press the reset button for 30 seconds then release, then use PUT on the TFTP app to upload the FW file.
DLynch
Sep 23, 2021Aspirant
What do you change in the TFTP instructions in terms of static IP, subnet mask, etc to use with a satellite vs a router?
