DozzaF
Mar 15, 2021Tutor
Orbi Satellite RBS50v2 keeps dropping out.
I Purchased my Orbi system on the 27th Nov 2020. RBK50 with 1 satellite included. (so now out of warranty as I did not purchase the 'additional warenty') Due to covid my wife has been working fo...
DozzaF
Mar 15, 2021Tutor
HI
All devices are running v2.7.2.104
Cheers
Dozza
vajim
Mar 15, 2021Master
DozzaF wrote:HI
Cheers
Dozza
Please do a search for Firmware v2.7.2.104.
Lots of problems being reported. If I say anything I get slapped around.
Or.....you stay with your original post here and wait for others to flood you with 100's of questions attempting to fix a fouled firmware version.
Your choice....enjo
- DozzaFMar 15, 2021Tutor
It Is wierd that it only affects the one satellite, which of course is why I'll be swapping the unit for a new one. (its coming tomorrow)
Cheers
Dozza
- vajimMar 15, 2021Master
DozzaF wrote:It Is wierd that it only affects the one satellite, which of course is why I'll be swapping the unit for a new one. (its coming tomorrow)
Cheers
Dozza
how is it that you point to that one sat?
are you using ethernet to connect to it?
only 1 sat ever drops out. Always the same sat
Only the router is connected via ethenet
Cheers
Dozza
- CrimpOnMar 15, 2021Guru - Experienced User
Please report what happens with the new satellite.
Wife is amazingly patient. I would have commandeered that dining room table long ago.
LOL.
Will report back, for sure.
