leventoz
Nov 17, 2018Guide
Orbi Satellite Redirects all web pages to own page saying "Your Connection Is not Private"
Recently, out of the blue (perhaps due to an automatic upgrade?) my WiFi network originating from the the Orbi satellites stopped working. The WiFi with the Router was fine. They're all on v2.2.1.210...
ctchan
Nov 19, 2018Aspirant
I have the exact same problem with one of the satellite. The backhaul keeps saying 'Config sync", and any device connected to the satellite will not connect to the internet and return an invalid page. My other satellite is working fine. I have not found an answer, trying may different things like reset, reconnect, downgrade/update firmware - but to no success.
I was beginning to think my satellite was defective and faulty - but see others have the same issue - which seems too coincident. It might be related to the latest firmware.. leventoz let me know if you find any answer.
I'm comtemplating dumping Orbi.. firmware still seems too buggy.
leventoz
Nov 19, 2018Guide
I agree that this stuff is too buggy, far from configure and forget. So far what has worked for me is reset both satellites by keeping the reset button down for 7 seconds. It's started working again, I guess I will have to keep doing this if the issue reoccurs until Netgear realizes there's an issue and pushes a fix.
I would have jumped ship long ago if I knew that an alternative would be less buggy. Unfortunately, knowing how these companies all operate, I know they all suffer from the same quality problems.
- FURRYe38Nov 19, 2018Guru - Experienced User
Have you tried the suggestions?
Please give feedback to questions presented.
The FW has been working for others.
- leventozNov 19, 2018Guide
Thanks Furry, but "do a factory reset" is not a viable option for me. I don't want to spend my weekends trying to get around Orbi's issues. I want to put this out there: the network was working fine only unti recently (since the last time I had to reset the satellites, which was a long time ago) and then the issue started propping up. I didnot do anything to have caused this. If I'm going to have to reconfigure my network, I might as well buy Linksys and try my luck with them.
As for the suggestion of toggle daisy-chain, I can say that if a check-box does the opposite of what it says, it indicates the sad state of affairs when it comes to engineering/quality control. I didn't do this suggestion, because it doesn't make sense to me. If it works for a while, then quits working after some time, then I imagine the configuration is fine - since it *was* working for a while.
Assigning static IPs to the satellites seem like a reasonable thing to try, which I will if it stops working again.
For the record, my router is connected directy to WebPass.net's ethernet cable that comes out of the wall. I don't have a cable modem.
I know that doing factory resets isn't fun, however it has resolved problems. There not alot fo users posting about this. So it is a last resort. If you did a reset a "Long time ago". It maybe time fore a new. There are just some few FW code that when applied over old code and user configurations do not work right until a factory reset has been performed. Sometimes even doing a manual load of FW helps as well.
I have not seen this issue since installing my Orbi and my friends Orbi.
Yes assigning IP reservations to satellites and devices helps and is good for keeping IP addresses ON devices.
Something to try. If you still experience problems, you'll need to contact NG support and get there help on this. Good luck.
- ctchanNov 21, 2018Aspirant
I tried holding down the reset for even 10 seconds and re-synced it, but it still has the same issue - backhaul still stays 'Config sync'.
Has anyone found out why the RBS50 Satellite stays in Config sync and only returns the routers own page for any connected wireless device??
- leventozNov 21, 2018Guide
I found (or believe) that the status value the website shows for the satellites are practically unreliable. Even the wired/wireless is incorrect most of the time. It's mind boggling how broken everything is. I would forget about checking the status on the web page and do real tests with devices. If you continue to have the "your connection is not private" issue, there are some suggestions earlier in this thread that you can try.
