leejr
Jan 27, 2020Aspirant
Orbi Satellite running slow.
I have an RBR 50 router with 2 satellites RBS50's. One of the satellites is much slower and more lag than the router and satellite. If I disconect the power of the slow satellite my phone will conn...
Jan 27, 2020Guru - Experienced User
You can try updating to v2.5.1.8.
Have you swapped locations with RBSs?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
How are the RBS placed in relation to the RBR? Out in a straight line or in a star formation?
- leejrJan 28, 2020Aspirant
Hi Furrye38,
I updated to v2.5.1.8.
I have not swapped location yet. Good idea, i will do that.
Mfr and model# of the ISP modem ARRIS Touchstone SB6183
Cox cable is our internet service.
Home is 2900 sqft.
About 35' from RBR50 to the RBS50's setup like a wide V with the RBR at the bottom of the V.
Connection always shows good to the satellites.
I set manual ch 6 on 2.4Ghz and 44 on 5Ghz
I dont share the wifi with anyone. Is that what you mean with wifi neighbors?
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings.......DONE
- FURRYe38Jan 28, 2020Guru - Experienced User
WiFi neighbors means that house many surrouding wifi neighbors are near by? Alot or maybe just a few?
Keep us posted.
