kaydeeloo
Jan 28, 2020Aspirant
Orbi Satellite set up its own SSID
I have had an Orbi router and a wall plug in satellite for a few years. I added a new plug in satellite a few weeks ago (original one is named Satellite-1, new one is Satellite-2). I have been checki...
- Jan 28, 2020
Multiple hard resets (with a paper clip) and multiple satellite moves and it's fixed. The two extra networks are gone and devices are attaching to both satellites.
Jan 28, 2020Guru - Experienced User
What Firmware is currently loaded on the RBR and RBSs?
The default SSID name is being used because the RBS didn't sync correctly or has not been sync'd to the RBR. Be sure you press the sync button on the RBR then on the RBS.
Ensure FW is the same version between the RBR and RBS.
- kaydeelooJan 28, 2020Aspirant
all firmware shows up to date. I'll try to re-sync it though and get back to you!
RBR40: V2.3.4.30.
RBW30-Sat 1: V2.3.0.4.
RBW30-Sat 2: V2.3.5.6
- FURRYe38Jan 28, 2020Guru - Experienced User
RBW 1 is behind on FW. You can manually download FW and update it.
OK, so I downloaded the new FW. When I browse and try to upload it, it says "please assign the correct file. The file format is .img" - the file I downloaded is .chk. What now? :womanembarrassed:
FURRYe38 wrote:RBW 1 is behind on FW. You can manually download FW and update it.
