kaydeeloo
Jan 28, 2020Aspirant
Orbi Satellite set up its own SSID
I have had an Orbi router and a wall plug in satellite for a few years. I added a new plug in satellite a few weeks ago (original one is named Satellite-1, new one is Satellite-2). I have been checki...
- Jan 28, 2020
Multiple hard resets (with a paper clip) and multiple satellite moves and it's fixed. The two extra networks are gone and devices are attaching to both satellites.
kaydeeloo
Hi, so it's me again. :womanfrustrated: I have figured out why it's happening, I just don't know how to fix it. I'll call Tech Support tomorrow, but I thought I'd circle back to you. Here is the issue. Webpage for Sat 1, shows both 2.4 & 5 GHz connections on the ORBI66, Security Type PA2-PSK[AES]. Webpage for Sat 2, shows 2.4 on ORBI51, Security Type WPA2-PSK[AES] and 5 GHz on ORBI66, Security Type None. Thanks for your help today!
kaydeeloo
- FURRYe38Jan 29, 2020Guru - Experienced User
Glad you got it working. One thing I recommend doing, change the SSID name from the default one used on the RBR to something different and more custom. Can be anything and make it something fun. One reason why you might have had issues is that your using Orbis default wifi SSID name which can work however was ment to be a temporary SSID name during setup and is highly recommended that users change this name to something different and custom. This will help avoid connection issues later on during troubleshooting.
Enjoy. :smileywink:
