Bandito
Dec 30, 2018Luminary
Orbi Satellite Slowdown
I continue to have problems with one Orbi satellite that after two-three days of use slows it's throughput dramatically. I can normally connect and get a full 300 Mpbs connection via the satellite, ...
Bandito
As I mentioned, I already replaced the satellite and it made no difference. The new one does the same thing as the original one did. Also, I’m not inclined to pay the support fee as there isn’t anything else that they can do to my knowledge. Netgear promises fixes in future updates and strings you along until your warranty is up and then you’re on your own.
Dec 31, 2018Guru - Experienced User
SO if you turn off the the working satellite and use the new one, same thing still happens? What is the setting currently on Daisy Chain?
Try setting it for checked as enabled.
Are you using manual channels on 2.4Ghz and 5Ghz? Try 1, 6 or 11 on 2.4 and 36 thru 48 on 5Ghz.
Seems that if one satellite doesnt' work and a 2nd one doesn't, wondering if the router could be faulty...
- BanditoDec 31, 2018Luminary
Yes, exactly. The original and replacement both experience the slowdown after a couple of days in operation.
I don’t believe the router is at fault as the other satellite works at full speed and if I go and link directly to the router itself, I still get a full speed connection.
Thanks for for the suggestion. I think it’s highly unlikely to be the culprit, but it is a possibility.
- FURRYe38Dec 31, 2018Guru - Experienced User
Might try a FW re-load on both router and the one satellite using IE11 or FF. Do a full factory reset and set up from scratch on both. Turn OFF The working satellite and see if the one in question shows the problem or not...
- Blanca_OJan 03, 2019NETGEAR Employee Retired
Hi Bandito
We’d greatly appreciate hearing your feedback letting us know if the information FURRYe38 provided has helped resolve your issue or if you need further assistance.
If issue still persist, please PM me your name, email address, phone number and device serial number so we can have our support team look into this issue further.
Blanca
Community Team
- ekhalilJan 03, 2019Master
Bandito, one question, do you have any wired devices connected to the "bad" Satellite? Any mesh speakers (e.g. Sonos)? :)
- BanditoJan 04, 2019Luminary
The only thing wired to the ORBI satellite is a Blu-ray player that generally is turned off.
I do have Sonos speakers, but they connect via a Sonos Boost.
