Bandito
Dec 30, 2018Luminary
Orbi Satellite Slowdown
I continue to have problems with one Orbi satellite that after two-three days of use slows it's throughput dramatically. I can normally connect and get a full 300 Mpbs connection via the satellite, ...
Bandito
Jan 11, 2019Luminary
Well, I redeployed my Orbi system and moved the Sonos speakers over to WiFi and off of Sonosnet and then turned off the Boost. The system has been running like this for two days now and when I went to do app updates on my iPhone today, I noticed that they were slow. I did a speed test and sure enough, the satellite has slowed down as usual.
Thanks for the suggestion ekhalil, but unfortunately that isn’t the problem that I’m encountering.
Any other ideas?
Bandito
Jan 14, 2019Luminary
I have been contacted by Netgear Technical Support and we are working on try to resolve the issue. If we figure out what’s going on, I’ll update here.
- mdbritFeb 18, 2019Aspirant
Any update on this?
My Orbi system is doing the exact same thing. After a restart I get 4-500mbps. Eventually over time I will check it and it's down to 20-30. I have gigabit fiber internet. Really frustrating. ABout to give up on it as what's the point of paying for gig ethernet otherwise??
- FURRYe38Feb 19, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
Are you speed testing wireless or wired?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try enabling Beamforming and MIMO.
Daisy Chain, Fast Roaming, IPv6
mdbrit wrote:
Any update on this?
- BanditoFeb 22, 2019Luminary
Netgear has me on beta firmware currently, but it does the exact same thing. Every 2-3 days the speed drops drmatically.
it would appear by the connection speeds that the backhaul is dropping down to one of the 2.4 GHz bands, but the system still reports that it’s connected via 5 GHz. It’s really frustrating and ruins the experience of an otherwise great system. <Sigh>
- ekhalilFeb 22, 2019Master
Backhaul links in Orbi use DFS channels. It can be that periodically your Orbi detects radar signals and changes the backhaul to other channels which will affect the throughput.
There is a log file in Orbi that logs radar detections with timestamps. Please follow the following steps to print your radar detection logs and see if the times correspond with when you think the speed goes down:
- From browser go to the router's debug page (http://192.168.1.1/debug.htm). Use your router's IP address or http://orbilogin.com/debug.htm
- Enter admin as user name and your router’s management password
- Tick "Enable Telnet" option
- Use Telnet to connect to your Router telnet 192.168.1.1 and enter admin and the same password as above
- Enter the command:
- root@RBR50:~# cat /var/radardetect.log
- BanditoFeb 24, 2019Luminary
I checked for the radardetect.log file, but it doesn't exist.
root@RBR50:/# cat /var/radardetect.log
cat: can't open '/var/radardetect.log': No such file or directory
I also browsed through the /var directory to see if there was anything else that came close to the radar name, but there was nothing.
I didn't think that this was very likely as we live in the middle of a large development with slow speeds and are about a mile away from the nearest highway.
Thanks for the recommendation. It's always good to check everything, but unfortunately it appears to be another dead end.
