Bandito
Dec 30, 2018Luminary
Orbi Satellite Slowdown
I continue to have problems with one Orbi satellite that after two-three days of use slows it's throughput dramatically. I can normally connect and get a full 300 Mpbs connection via the satellite, ...
Aug 16, 2019Guru - Experienced User
Are you getting near 900Mbps on a wired PC connected to the RBR?
aleef wrote:Hey bandito, please post here if you (or the support ppl) figured things out. I just spent the whole day trying to figure out what was wrong with my wifi (I was only getting 20Mbps on a 1Gbps connection). Unfortunatelly I've only found your post after I got to reset the sattelite. I like to find the root of the problems so reboots and resets are the last items on my troubleshooting lists (I know, I'm masochistic that way). Anyways, any update on this? Are the NG ppl still trying to find the issue?
aleef
Aug 16, 2019Aspirant
I'm not home. I'll send all the info tomorrow. I am getting over 900mbps on a wired connection straight in the isp router. About 550mbps on a wired connection to the orbi router. About 400mbps on a wireless connection to the orbi router (was hard stuck at 20mbps on all my devices before the router and satelite reboot). I just updated the firmware to the latest available (can't remember the version).
- FURRYe38Aug 16, 2019Guru - Experienced User
If the ISP modem has a built in router, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
