Bandito
Dec 30, 2018Luminary
Orbi Satellite Slowdown
I continue to have problems with one Orbi satellite that after two-three days of use slows it's throughput dramatically. I can normally connect and get a full 300 Mpbs connection via the satellite, ...
aleef
Aug 16, 2019Aspirant
Hey bandito, please post here if you (or the support ppl) figured things out. I just spent the whole day trying to figure out what was wrong with my wifi (I was only getting 20Mbps on a 1Gbps connection). Unfortunatelly I've only found your post after I got to reset the sattelite. I like to find the root of the problems so reboots and resets are the last items on my troubleshooting lists (I know, I'm masochistic that way). Anyways, any update on this? Are the NG ppl still trying to find the issue?
Bandito
Aug 17, 2019Luminary
The ticket is still open with Netgear, but I haven’t heard anything back from them for about 3 months now, so I’m not very hopeful that anything will get fixed.
I am on the current firmware, 2.3.5.30, but no fixes have been mentioned that would seem to apply to the slowdown issue.
I recently switched to a eero system to try it out and it seemed to work well, but I had some disconnects with my Hue lighting and Siri would report that she could turn on/off the lights. That and the fact that I only got speeds in the 60-80 Mbs range led me to return them. I just can’t find anything with the throughput of the Orbi’s when they are working correctly, so keep coming back to them. My Internet speed is 300 Mbs and the Orbi’s generally give me between 250-300 Mbs throughput, so they make me feel like I’m getting my money’s worth from my ISP. 😁
interestingly, I still had a dead spot in my living room and I found an add-on satellite on sale at the local Fry’s store, so I picked it up and placed it in the living room. This eliminated the dead spot and, knock on wood, I haven’t had any slowdowns since. It makes no sense as to why this would fix anything, but I’m not gonna argue with it. I just hope that by posting this here it doesn’t jinx it.
Time will tell, but it’s been a couple of weeks of full throughput now, where before I couldn’t go beyond four days.
