Bandito
Dec 30, 2018Luminary
Orbi Satellite Slowdown
I continue to have problems with one Orbi satellite that after two-three days of use slows it's throughput dramatically. I can normally connect and get a full 300 Mpbs connection via the satellite, ...
tannertanner
Aug 20, 2019Aspirant
I am having this same issue and would love a fix. This has been happening since I set up the system about 10 months ago. If I restart the system everything goes back to normal and I get the full speed of my internet connection (around 250mbps). After a few days the speed on all devices drops to 40mbps or less. The only thing that seems to resolve the issue is to restart the router. This is happening on my laptop even in the same room as the base unit so it isn't a week signal issue. One day it will be full speed and the next with no other changes it drops to 35 - 40mbps.
I have the Orbi Orbi RBK20W (AC2200).
- ekhalilAug 20, 2019Master1. Can you please check which radio channels the slowed down devices are using during normal operation and when the issue appears. Don’t the devices change from 5 GHz to 2.4 GHz? Do you have fixed radio channels for 5 and 2.4 GHz bands?
2. What wired devices do you have attached to Orbi? Wired devices can cause loops in the system if wrongly configured.
3. What is the model of your ISP modem/router? Is Orbi operating in Router or AP mode?- tannertannerAug 20, 2019Aspirant
The issue has occurred on all radio channels as one of my early troubleshooting steps was to try different channels. The affected devices are all connected on the 5ghz band. I do have a few devices connecting on the 2.4ghz band but I am less concerned about the speed of those and therefore haven't checked if they are affected in any way.
Currently I have the 5ghz channel set to 36 and the 2.4ghz channel set to 01. In the past I have set 2.4ghz to auto as well as 06 and 11. I have also tried the 5ghz channel 40. When the slowdown occurs I have double checked what the client and what the orbi router report and they both state that the device is connected via 5ghz. So although the speed decline would seem like it is connecting at 2.4ghz that doesn't appear to be the case.
I have one wired device. It is a mac mini. Running speed tests on that computer show that it is getting the full speed that my internet connection allows. I have also unplugged that device and it did not improve the problem for my wireless devices. The computer is set to use DHCP and so does not really have any custom configuration and is operating properly so I don't believe there is any configuration issue or hardware issue with it.
I am using Comcast cable internet for my ISP and the modem is a Motorola MB7621 DOCSIS 3.0. It is not set up as a router so I do not have a double router (nat) situation going.
The orbi is operating in Router mode. A simple restart of the Orbi fixes the issue for days and my wired device never experiences any slowdowns so there shouldn't be any issues with my cable modem.
- FURRYe38Aug 20, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected..
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed on both RBR and RBS?
tannertanner wrote:The issue has occurred on all radio channels as one of my early troubleshooting steps was to try different channels. The affected devices are all connected on the 5ghz band. I do have a few devices connecting on the 2.4ghz band but I am less concerned about the speed of those and therefore haven't checked if they are affected in any way.
