Bandito
Dec 30, 2018Luminary
Orbi Satellite Slowdown
I continue to have problems with one Orbi satellite that after two-three days of use slows it's throughput dramatically. I can normally connect and get a full 300 Mpbs connection via the satellite, ...
futureAlec
Oct 21, 2019Guide
Ok call me crazy, but hear me out. This happens to me all the time too and lately looking at it in connected devices (iphone 11 pro max)
It seems to me (as of now very anecdotal) but when I experience slowness my device seems to be recognized as connected WIRED to the satellite.
Anyway, curious if anyone else notices this behavior or something similar.
- FURRYe38Oct 21, 2019Guru - Experienced User
What FW are you using? There is new FW for the RBK and RBR 50 series systems
Is the RBS the only one or do you have more then one RBS?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
futureAlec wrote:Ok call me crazy, but hear me out. This happens to me all the time too and lately looking at it in connected devices (iphone 11 pro max)
- futureAlecOct 28, 2019Guide
FURRYe38 :
I have just updated to the latest firmware *hoping* this would fix it bus alas, it has not. V2.5.0.38
Distance between router and satellite would be irrelevant I would think since it is wired backhaul but about 40 ft.
I am using auto, out of the box config (for the most part. See Below). No Neighbors close at all.
I enabled all of these settings and it did not change anything.
Interestingly enough... When I unplug the satellite in question I still get crappy speeds (~50mbps) until I wait (seems to potentially clear itself up after a while) or restart the main router and then it's fine.
I am very close to just going and buying into the Asus solution of buying whichever routers you like and they all work together.
- FURRYe38Oct 28, 2019Guru - Experienced User
Is the RBS directly connected to the back of the RBR or connected with a switch in between the RBR and RBS?
futureAlec wrote:FURRYe38 :
