Bandito
Dec 30, 2018Luminary
Orbi Satellite Slowdown
I continue to have problems with one Orbi satellite that after two-three days of use slows it's throughput dramatically. I can normally connect and get a full 300 Mpbs connection via the satellite, ...
futureAlec
Oct 21, 2019Guide
Ok call me crazy, but hear me out. This happens to me all the time too and lately looking at it in connected devices (iphone 11 pro max)
It seems to me (as of now very anecdotal) but when I experience slowness my device seems to be recognized as connected WIRED to the satellite.
Anyway, curious if anyone else notices this behavior or something similar.
Oct 21, 2019Guru - Experienced User
What FW are you using? There is new FW for the RBK and RBR 50 series systems
Is the RBS the only one or do you have more then one RBS?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
futureAlec wrote:Ok call me crazy, but hear me out. This happens to me all the time too and lately looking at it in connected devices (iphone 11 pro max)
