Bandito
Dec 30, 2018Luminary
Orbi Satellite Slowdown
I continue to have problems with one Orbi satellite that after two-three days of use slows it's throughput dramatically. I can normally connect and get a full 300 Mpbs connection via the satellite, ...
futureAlec
Oct 28, 2019Guide
Yes, I did a factory reset on both main and satellite with no change in behavior and it is connected directly, not through a switch.
Oct 28, 2019Guru - Experienced User
I just checked mine. The RBS is wire connected with 4 switches in between. Been online for 6 days now since the update.
System Uptime 06:17:45:42
Tested my iphone about 20 feet away from the RBS. Speeds are to spec. Not sure if 6 days is long enough for me to see this or not.
You might contact NG support and get some additional help and information on this...
futureAlec wrote:Yes, I did a factory reset on both main and satellite with no change in behavior and it is connected directly, not through a switch.
