bcbrewster
Mar 26, 2018Aspirant
Orbi Satellite Speed 50% of Router Speed
My download speeds, as measured by speedtest.net are about 50% lower when using the satellites as opposed to the base router. Is this normal behavior? Any way to get speeds through satellites?
Mar 26, 2018Guru - Experienced User
What speeds UP and Down are you getting at the router?
Try ethernet backhaul?
What FW version are you using?
There is Beta available.
bcbrewster
I did a reboot of the router, then satellites. Seems to have worked and they are now consistent: Upload about 120 mbps, download 12 mbps. Will check further later. Thanks.
- FURRYe38Mar 26, 2018Guru - Experienced User
:smileywink:
