ADS-RBR50
Nov 11, 2021Aspirant
Orbi satellite speed test issues
I'm experiencing significantly slow internet speeds from the Orbi RBR50 Satelite despite the ORBI app speed test confirming the statelite is providing excellent download speed which contrary to the s...
Nov 12, 2021Guru - Experienced User
what firmware is on the satellite?
have you tried changing its location?
Have you tried factory resetting and re-adding the satellite?
- ADS-RBR50Nov 15, 2021Aspirant
Hello again, I have tested the satellite, as per your suggestions without luck. It appears to be an inherant problem with the ethernet ports. The fault only occurs if the satellite ether net port/s are used. The problem began when I tried running my desktop PC off of the satellite and soon after the satellite started to bug with slow to no internet. I've only owned my Orbi RBR50 router and RBS50 satellite for two years and never had a problem. I'd be super grateful if you had any suggestions to fix.. Thanks in advance
