Kevinrees7
Aug 15, 2017Initiate
Orbi satellite stuck on solid blue
I have an orbi rbr50 and rbs50. They have been great until a few days ago I noticed the satellite led lit solid blue and won't turn off. Solid blue for 10 seconds means a stable connection but it woul...
Dannyboyuk44
Aug 16, 2017Initiate
Mine is exactly the same. Any ideas?
Kevinrees7
Aug 18, 2017Initiate
So I ended up just turning the satellite unit off with the button on the back and left it off for several minutes. Turned it back on and the blue light turned off after about a minute. No clue what the issue was and it might happen again but now I know.
- dpdurstAug 19, 2017Luminary
Mine does that once in a while, Its seems to coincide with one of the connecitons having a device on it and the other doesn't. So my 5ghz devices connect but no 2.4ghz device and the light is blue solid and won't go out. Once a 2.4ghz device connects it goes out. Maybe just a coincidence but seems to match that scenario everytime I reboot it.
