Kevinrees7
Aug 15, 2017Initiate
Orbi satellite stuck on solid blue
I have an orbi rbr50 and rbs50. They have been great until a few days ago I noticed the satellite led lit solid blue and won't turn off. Solid blue for 10 seconds means a stable connection but it woul...
BowenQin
Oct 17, 2017Aspirant
That is because the satellite changing from 2.4G to 5G if you keep eyes on admin portal.
Retired_Member
Dec 18, 2017But that doesn’t explain the blue light staying on
- dpdurstDec 18, 2017Luminary
A few things I noticed on this issue
1. Reboot and no connections are made 5ghz or 2.4ghz the blue light seems to stay on
2. Running fine but for some reason connection between Sat and Router show 2.4ghz instead of 5ghz the blue light stays on
3. Reboot and blue light stays on for an undetermined amount of time.
No rime or reason, just what I noticed over the last few months on my setup.
- Retired_MemberDec 19, 2017
did the power reset last night and the blue light remains off.
