Kevinrees7
Aug 15, 2017Initiate
Orbi satellite stuck on solid blue
I have an orbi rbr50 and rbs50. They have been great until a few days ago I noticed the satellite led lit solid blue and won't turn off. Solid blue for 10 seconds means a stable connection but it woul...
May 07, 2018Guru - Experienced User
Whats the distance between the router and satelllite? starting should be 30 feet minimim. Mines 40 feet in a 5000sq ft home.
Whats the size of your home?
WHTMTN wrote:
Same problem stuck on blue. Have had this issue before and each time I shut off power and reboot. Light goes away but then periodically happens again. No idea why except maybe that the satellite is a bit too far from RBR and this somehow affects the connection lights.
Retired_Member
May 07, 2018
what's the factor of the home size if you're clearly discussing router to sat distance?
