McSmarte
Jun 16, 2019Tutor
Orbi satellite super slow connection - backhaul issue?
Having just upgraded my internet connection from 70Mbit to 230Mbit, I was a bit annoyed that I only got mediocre speed when sitting in my garden (~30Mbit) My friend had just bought the 3 units Orbi R...
- Jul 26, 2019
I have had great success using a firmware that was released a few weeks ago. V2.3.5.30. I now get the exact same test results on both router and satellite, around 230Mbit.
Enable Daisy-Chain Topology
Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices
Enable MU-MIMO
Enable Fast Roaming
richie510
Jul 08, 2019Tutor
I finally got slightly better speeds after talking with a netgear rep and changing the channel for 5G. This seemed really fishy to me, but initially worked great. Then started to wane after a while. Since then I have reconfigured my network to get the satellite closer to the router, but it is still unreliable, but usually better than 50M, and often a 150-250M connection for the backhaul. The
It is so strange to me that changing the channel could help, and that there is no setting for "Auto". This thing should know what channel to be on and just use that. Also, the channel i'm selecting is not for the backhaul, it is for the device connections, so this is doubly strange. It is also really weird that after resetting to factory settings, the thing had a bunch of features turned off that make the whole thing work correctly like "fast roaming".
I'm finally done listening to the wirecutter for networking advice. I'm likely done with netgear as well. I do not trust google, but their device will detect problems and shift accordingly. This system may be fast, but it is just a dumb box.
McSmarte
Jul 26, 2019Tutor
Enable MU-MIMO
Enable Fast Roaming
- FURRYe38Jul 27, 2019Guru - Experienced User
And is the speed to spec for what you pay from your ISP?
McSmarte wrote:I have had great success using a firmware that was released a few weeks ago. V2.3.5.30. I now get the exact same test results on both router and satellite, around 230Mbit.
Enable MU-MIMO
Enable Fast Roaming- McSmarteJul 28, 2019TutorYes, the issue I had was the backhaul being slow and eventually dropping the connecting altogether - my router always ran full speed.
