TedsNotHere
Mar 08, 2020Aspirant
orbi satellite to satellite connection
Hello, My question is with the Orbi satellites and their connection with eachother and the router. I'm wondering if the satallites get a signal from eachother or just the router. This is my curren...
Mar 09, 2020Guru - Experienced User
What Firmware version is currently loaded? FW same on all Orbi devices?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
TedsNotHere wrote:Hello, My question is with the Orbi satellites and their connection with eachother and the router. I'm wondering if the satallites get a signal from eachother or just the router.
This is my current configruation R -> S1 -> S2 (router on one side of house and S1 one the other side of house with a second satellite upstairs on same side as S1. The S2 always displays orange because it has synced but only has a fair connection. The connection between R & S1 has a wired backhaul so connection is good.
I really need S2 to have a good wireless connection so wondering if I need to reconfigure like so: S1 - > R -> S2
Thanks!
