PaulCev
Jun 21, 2019Aspirant
Orbi Satellite Transmit/Operation
I am sorry for this question. However I am having a hard time finding current information.
Info:
House 3,000 SFT
ISP ATT U-Verse Router/WiFi Located in office upstairs
Netgear System Orbi Mini RBK22
Exisitng WiFi cover downstairs TV room and back bedroom - POOR
I know that I must turn off U-Verse WiFi and also set Orbi up as AP
However I am seeing conflicting information regarding the actual operation of the system and whether the satellites can communicate with each other unless hard wired.
So here are my questions:
1. If the Orbi is in "AP only" mode will it still communicate with the Satellites?
2. Do the satellites recieve a WiFi signal from the Orbi router, and do they transmit to each other and other WiFi devices?
3. Or do the satellites recieve a WiFi signal from the Orbi router, and you only can hard wire (LAN) cable other devices to them?
4. Are the LAN connections on the back of the satellites only for non WiFI devices.
5. I have an ATT installed hard wire (LAN) router downstairs which ATT installed a very weak extender.
- If I put a satellite in place of the router will this work? OR
- Should I LAN connect a Satellite?
6. Should I opt for a 1 router and 2 satellite system due to the number of walls to get to the back of the house?
Thank you!!!
PaulCev wrote:I am sorry for this question. However I am having a hard time finding current information.
Info:
House 3,000 SFT
1. If the Orbi is in "AP only" mode will it still communicate with the Satellites? YES
2. Do the satellites recieve a WiFi signal from the Orbi router, and do they transmit to each other and other WiFi devices? YES
3. Or do the satellites recieve a WiFi signal from the Orbi router, and you only can hard wire (LAN) cable other devices to them? No, wireless and wired will work. It'll function as a full AP working with both wired and wireless connections.
4. Are the LAN connections on the back of the satellites only for non WiFI devices. Not sure exactly what you're asking here. the ethernet ports act as regular ethernet ports.
- Should I LAN connect a Satellite? I'd just use the one router att provider and remove any others. the orbis do a great job of providing wireless and if you have another wireless device broadcasting, it only adds interference to the signal.
6. Should I opt for a 1 router and 2 satellite system due to the number of walls to get to the back of the house? Thats hard to tell without actually testing it. I prefer to over engineer (over network) versus under but it depends on what your goals/budget/desires are.
Thank you!!!
Basically orbi works great. I have a 3200 sq ft house but I use an orbi and 2 satellites to make sure I have adequate coverage. I have to spread them out a bit as orbis need 30ft distance between them. You can use both the wireless backhaul and/or the wired backhaul for connecting the router and satellites. There's a bunch of possibilites with that setup.
