Taybraham
Jul 02, 2019Follower
Orbi satellite trouble
Every night I have to unplug my orbi satellite and plug it back in in order to use the smart function on my new Roku tv. I am new to Orbi as well and was really excited about being able to extend the ...
Jul 02, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
