Dilev
Jul 23, 2020Follower
Orbi satellite wall plug satellite is not working
The model is RBW 30 We have the router plus 2 satellites and the wall plug. When the RBW30 is plugged in it shows a pale purple color. I have tried to reset it. The color is amber and then goes to a s...
Jul 23, 2020Guru - Experienced User
Try connecting the RBSW near or in the same room as the RBR. Factory reset and press the sync button on the RBS and RBR.
The other RBSW works?
