MeGrimlock
Jan 16, 2018Apprentice
Orbi Satellite Will Not Factory Reset?
I have an Orbi system with one extra satellite, all running the current firware V2.1.1.16. Lately, the upstairs satellite will work for periods of time, then drop all internet connection, even thoug...
Sep 13, 2018Guru - Experienced User
Make sure you walk thru the set up wizard and write down important information for safe keeping and use later on if needed.
Enjoy, :smileywink:
Kleumas wrote:
Yes! It worked! Not immediately though. But after repeating the exact same thing there times.. I did get different result. Uhm.. Yes.
But it works! Thank you for your help!
