jblack68
Aug 30, 2018Apprentice
Orbi Satellite will not reconnect unless I disconnect all ethernet devices first
Hi,
I have recently figurered out why my Satellite will not reconnect to my Orbi Router because there was ethernet devices connected to the Satellite - once i removed them and rebooted Satellit...
Aug 30, 2018Guru - Experienced User
What FW is currently loaded?
What LAN devices do you have connected to the satellite?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
